by: TimeActor
#56046
I´ve download the complete Patch for my Ryzen CPU 3900 X (17h) and edit my config.plist before update from 10.15.3 to 10.15.4.
When I boot with OC I see the following lines - after that my system boot into Catalina 10.15.4.
Any suggestions about that or solution idea? Much Thx!
#56047
Check your OC config. Match your UEFI settings to this. Don't remove or add what's missing as I'm using 0.5.7. Only modify settings you've already got there,
by: TimeActor
#56051
Thank you Shaneee - i´ll try this after work (Home Office).
Hello Shaneee, I didn't have an output folder in UEFI cause OC 0.55 didn't have one. (´ve check this before change something)
Another Idea?
Bildschirmfoto 2020-03-30 um 18.44.30.png (88.58 KiB) Viewed 203 times
#56055
Some of those options will still be there just under a different category. Just search the file for them.
by: TimeActor
#56059
Sorry no success that didn't´change anything. What i don't understand. I have only changed my config.plist with new patch 17h for my ryzen before I update to 10.15.4.
#56074
Try using 0.5.6. Test on a USB first.
by: TimeActor
#56079
Yes i changed to 0.5.6. System startet smooth like before but now i have an issue with my keyboard. Mouse is good but keyboard without respond. When i plug out the keyboard on the back usb and plugin on front usb (i´ve only one in front) my keyboard is fully working. SMBIOS is set to iMacPro 1,1 . What should i do?
Is it possible that you look at my efi which i´ve put into my last post of my Success Story today?
Thank you Shaneee!
#56082
TimeActor wrote:Yes i changed to 0.5.6. System startet smooth like before but now i have an issue with my keyboard. Mouse is good but keyboard without respond. When i plug out the keyboard on the back usb and plugin on front usb (i´ve only one in front) my keyboard is fully working. SMBIOS is set to iMacPro 1,1 . What should i do?
Thank you Shaneee!
From looking at some different X570 boards the USB seems to be the same throughout. Try using these two USB SSDTs. You'll need to add them to the ACPI folder in your EFI and add them to the config under ACPI -> Add
(2.25 KiB) Downloaded 12 times
by: TimeActor
#56090
One of your SSDT do the trick :thumbup: Thank you.
My second internal SSD displays now as external. I know its a bit cosmetic but before in 10.15.3 it shows as internal. Is there a workaround?
