#52431
There is no kernel. We use kernel patches via the bootloader now. https://vanilla.amd-osx.com/
by: oofeydoodless
#52452
Shaneee wrote: Sat Nov 16, 2019 1:52 pm There is no kernel. We use kernel patches via the bootloader now. https://vanilla.amd-osx.com/
I have tried time and time again to install macOS sierra, high sierra, Mojave, and Catalina and I always fail. is there any tutorial for my specs?
CPU-FX(tm)-8320 8 core processor
GPU-Radeon FX 560 4 gigs dedicated vram
#52454
Yes that tutorial supports your setup. You need the 15h_16h patches.
by: oofeydoodless
#52456
Shaneee wrote: Sun Nov 17, 2019 1:34 pm Yes that tutorial supports your setup. You need the 15h_16h patches.
Do I just use the config.plist that is in there or do I need to update that, and others if needed?
#52471
Read the tutorial. You'll need the config.plist for Clover that is provided along with kexts for your setup etc.
by: oofeydoodless
#52478
which kexts are the baseline required kexts that i need in order to boot correctly for my personal system. i’ve failed at many different kext combos
