by: OnSale
#48377
after I install new themes and reboot my pc now Mac OS won't boot to MacOS system anymore. doesn't matter which option I select it only give me the BIG Circle and computer shut down after few second. I'm only able to boot to windows under Clover Option the rest are not working.
@felipelacerda , did you read my second edit? […]
Same problem my friend :problem: Have you the sh[…]
I sit with the same sleep problem, no USB issue[…]
You should not need the DSDT.aml nor the SSDT-EC[…]
