#48307
Looking to build a budget Hackintosh mostly to use for Ableton Live (don't want to use Windows or buy a Mac lol). Specs are below:
CPU: AMD FX-8350
Mobo: Gigabyte - GA-990FXA-UD5 ATX AM3+
Memory: Patriot Signature 8GB
Storage: Kingston A400 120G PCIe M.2 2280 Internal SSD - SA400M8/120G
Graphics Card: MSI AMD Radeon R72402364P 2GB DDR3 VGA/DVI/HDMI Low Profile PCI-Express Video Card
Case: Corsair SPEC-04 ATX Mid Tower
Sound Card: (using my Focusrite Scarlett 2i2 for external sound)
How would this be for a Hackintosh? Also, would I have to use a modified distro for AMD like Niresh or can I install a real macOS copy? If I can do the real macOS copy, how would I go about doing that?
your problem with the russian language at installa[…]
Hello every1 I followed this guide to made OpenCo[…]
@teseraph , A quick look at the Thunderbolt SSDT[…]
10.15.3 install issue
I'm seeing exactly the same error. I did enabled […]
