#56866
ASRock X570 Creator sounds like an ideal choice for a ryzentosh, is it?
My experience with Asus’ higher-end board has been really good, so I’m slightly biased to it when it comes to motherboard choices (awesome bios, quality pcb components, studio-grade audio performance — isolated audio path!)
I’m not afraid to get my hands dirty and I’m willing to do the work but I need a good motherboard to start with.
Is there a motherboard that doesn’t have a sleep or USB related issue? Basically one that works out of the box for basic Mac functionality.
I don’t use Adobe products. My main use for the machine would be photo editing (Aperture, Luminar, Pixelmator), SketchUp modeling, basic recording on Logic Pro X, Mainstage.
Any thoughts would be appreciated.
#56867
You can read through SNAZZY LABS RYZENSHINE BUILD WITH ASROCK X570 CREATOR -- THUNDERBOLT WITH HOT PLUG?.
It looks like Gigabyte is a better choice for building a Ryzentosh... how much better I don't know.
