by: Rickyandika
#56280
Hi, i have successfully create my first hackintosh ever. Im using Ryzen 2600 , AsRock Ab350 Pro4, with saphire nitro + rx 580 4gb.. it boot up fine and everything works but i think i have a few minor problem with the GPU.
First if i were to use a software screen recorder like quicktime or obs the end result would be very blurry like it was 480p(the file size shows 1080p and on obs i set everything to max at 1080)
Second, i think im getting way weaker GPU Performance on Mac vs windows. I have tried using geekbench and got 34977 on metal and 24967 on OpenCL. Does this number sounds right?
The kext i use for graphic are whatevergreen and lilu. Is there any other kext i should use to improve performance? I heard someone says i should enableATI buy im using opencore and as far as i know its not available?
by: tikizondo94
#56285
Normal GPU performance with Ryzen. I average 29K with Geekbench 5 in Compute/OpenCL with an RX580 8GB Model.
You can run AGPMInjector to create a GPU PowerManagement Kext that may help some. Attached is a link to the app. Just select your SMBIOS and card version.
https://github.com/Pavo-IM/AGPMInjector/releases
