by: r0bert0
#56241
Hi guys,
I've just completed my build. I've followed the AMD-OSX guide to crating my bootable USB
I got the OC no vault found error, so I changed to optional in my config
I know get to this screen, please see attached pic.
I've googled, but cannot find the answer
Can someone please help me?
many thanks
Rob
System details-
B450 Steel Legend
Ryzen 5 3600
Asus RX 580 Arez
8gb x 2 Ballistix 3000
Cooler Master AIO
#56243
You need to set your ScanPolicy to 0.
by: r0bert0
#56255
Shaneee, thank you so much. :thumbup:
I have now followed the guide and added serial numbers. Im stuck again. :thumbdown:
Please see attched photo.
Any help is very much appreciated.
Thanks
Rob
#56256
Check your BIOS settings. Enable HPET
by: r0bert0
#56270
Hi Shaneee,
There isnt an option in my BIOS for enable HPET, but I've chcked in System Devices and it is enabled.
Still getting the same screen on boot. What else can I try :?:
Hi guys,
After much messing around, I have got to this stage.
Can anyone help me with why it’s in Russian (I’m guessing I can changes that once installed) and also why I cannot select the drive to install to please. Sooooo close.
Thanks for any help you can give me.
Best regards
Rob
by: Apophis
#56334
Try removing `prev-lang:kbd` entry under NVRAM from your config.plist. And if you can't see your installer stick try a different USB Port.
