by: Maxime Di Meglio
#53675
Hello guys, I'm new here.
I followed the tutorial at https://vanilla.amd-osx.com/index.html and did everything mentionned, to install Mojave 10.14.6.
However after booting to the USB and going to the macOS installer in recovery, it just completely freezes after 10sec, whatever I try : making a new USB flashdrive, switching USB port, disabling the CPU overclock, RAM overclock, virtualization... I'm suspecting a kernel panic because after a reboot it says just before the verbose screen "System rebooted because of a panic" or something similar...
Here are my specs :
Ryzen 5 1600x @ stock
Gigabyte Vega 56 Gaming OC 8GB
ASUS Prime B350M-A motherboard
16GB Corsair Value memory @ stock
Samsung 840 EVO SSD using SATA
Seasonic 1300W Gold PSU (yeah I know it's overkill for my setup ^^)
128GB Emtec usb flashdrive
I've looked for other people with this issue but no luck with finding a fix... Any ideas ?
Thnaks a lot, looking forward to having a running Hackintosh ;)
PS: EFI folder zipped and uploaded here as attachment
(3.69 MiB) Downloaded 7 times
