by: aeros88
#47773
I’ve successfully got Mojave working 99% (specs in signature) - the last issue I’ve been unable to iron out is with WebKit (affecting Safari and Chrome). Certain sites cause Safari to reload:
“This webpage was reloaded because a problem occurred.” - before finally failing completely “A problem repeatedly occurred with [url]”
In Chrome, the problem happens to the same sites producing an “Aw, Snap!” message.
Firefox, however, seems to work 100% but I’d rather use Safari.
Sites I can confirm cause the error:
- Amazon - doing a search for anything
- Sourceforge - on the download page; 5 second counter starts then page crashes
- Trying to post here on the forum also causes it when moving the cursor to the Subject text field.
I’m attaching the crash logs for WebKit as well as my config.plist.
Loaded kexts are as follows:
/EFI/CLOVER/kexts/Other:
GenericUSBXHCI.kext NullCPUPowerManagement.kext RealtekRTL8111.kext VirtualSMC.kext WhateverGreen.kext
/Library/Extensions:
Lilu.kext VoodooHDA.kext
Edit: Attached Etre report
(3.36 KiB) Downloaded 9 times
(66.46 KiB) Downloaded 9 times
(32.32 KiB) Downloaded 11 times
ben higham liked this
#47776
Yes I believe I did.. that's under the Debug menu in Safari, correct? I'll have to double check.
I'm attempting to install High Sierra onto a secondary drive to see if the problem is still present.
