#47391
I have followed the vanilla Mojave tutorial (https://hack.slim.ovh/mojave/#/) to install version 1.14.1 and everything seems to be working fine, except for audio.
I've tried using VoodooHDA and AppleALC and both give me crackling audio whenever I am not moving the mouse or using CPU-intensive applications. I have disabled Core Performance Boost in the BIOS.
Egress liked this
#47906
Open the VoodooHDA.kext with Finder 'Show Package Contents' here open the info.plist with text editor search the <key>iGain</key> and set value to 0
Need AppleALC.kext and VoodooHDA.kext in EFI/CLOVER/kexts/Other. Open your config.plist with Clover Configurator in Devices-Audio-Inject section set your layout-id from this site https://github.com/acidanthera/AppleALC ... ted-codecs
Use the HDAS to HDEF rename in config.plist DSDT patches.
Restart.
Egress liked this
#49592
Trevor30 wrote: Thu May 09, 2019 9:10 pm Open the VoodooHDA.kext with Finder 'Show Package Contents' here open the info.plist with text editor search the <key>iGain</key> and set value to 0
Restart.
anyone test this? work or not?
@eziodavinci , No issue there. That's normal for […]
AMDMacOSX Catalian
Yes that tutorial supports your setup. You need th[…]
Hey, Successful build on my machine. MSI x470 […]
Hy, I updated the LILU and Evergreen kext which f[…]
