by: ScarAce1989
#53646
Hi,
I'm new to this. I'm looking for a way to install MacOS on my Ryzen 3900x with support for 32 bit apps. The MacOS version doesn't have to be Mojave. Any other version is fine too.
I installed MacOS using the Vanilla guide, but after installing I read 32 bit apps are not running.
Is it possible to run 32 bit apps on a Ryzen 3900x and if so, can someone help me with this?
Cheers.
by: freeubi
#56331
Install a high sierra, you can run 32bit on that.
There is no correlation on the cpu however
