#51758
hi guys,
thanks for all the hard work getting this stuff working, it really is amazing.
Im wondering though, how does anybody use it? There is obvious graphics lag using ATI gpus, and glitches everywhere. I know the drivers for ATI cards are supposed to be built into Mac OSX, but for example, Logic is unusable, as the song position pointer doesn't even scroll due to glitching. How are people solving this ?
Also, my motherboard is using a Killer 2500 ethernet port, but the kext for this doesn't seem to let it show up in mac os, I tried the 2.2.2 one as well. Im getting by using a Realtek USB one which I plugged in and does work, but wondering if anyone else had this issue.
AppleTV and red screen
Do you get a pink/purple-ish screen? I have the pu[…]
I have the same issue with my 57800 and sleep/wake[…]
I have the same HW. I have an USB Keyboard and a U[…]
I wanna your efi,and try it.Would u like to send t[…]
