#50809
I just restored from time machine on a new NVME and put my old NVME to the 2nd m.2 slot.
Everything worked out good; installed Clover and copied the EFI from the latest USB installer I created from the vanilla guide which is way easier than when I started my first hackintosh.
I noticed when I opened my clover configurator that I don't have anything in drivers64uefi but everything works!
I'm curious if drivers are still needed and what are they for now?
@felipelacerda , did you read my second edit? […]
Same problem my friend :problem: Have you the sh[…]
I sit with the same sleep problem, no USB issue[…]
You should not need the DSDT.aml nor the SSDT-EC[…]
