#50482
manoueltiger wrote:and what if I use a zen2 CPU ?
I thought 15h_16h was for older CPU ???
that's a greeeeeat information, thanks dude ;)
Yeah I am testing just right now to see how it goes, I have a Ryzen 3900X and a X570 mobo, I am crossing my fingers...
Inspector77 wrote:Hello i discover that if y use the vanilla kernel patches from 15h_16h cpus in my ryzen 2600x
i have good opencl benchmark.
With 15h_16_h config.plist :
4961 Single-Core Score
24951 Multi-Core Score
121131 OpenCL Score
With 17_h config.plist :
4821 Single-Core Score
24446 Multi-Core Score
41035 OpenCL Score
Perhaps one of the kernel patches It's the cause of the poor opencl perfomance.
Please test it if you have a 17h processor.
my system:
ryzen 2600x
MSI B450 Gaming plus
16gb Corsair 3000mhz
240 ssd
Wow I already tested the 15h_16h patches in Zen2 3900X with x570 mobo and yes the performance is quite better, but I had to make some changes to make it work, I have to add the algrey - cpu_topology_sort -disable _x86_validate_topology from the 17h patches to the old ones, and the machine booted up, without that no. And the performance is really good in 3D now, in games in all scenarios. And the processor performance is really good. But I think is just one kernel patch the problematic, because I was mixing some configs from one to the another and when I use one the 3D performance got really low. I will keep updated about my investigations. But until now, full Usb 3.1/3.2, native audio with AppleALC, a lot better graphics performance with VDAHardware support for encode/decode h.264/h.265, until now the performance is lot better than my Intel Hackintosh and I got it because of you people, I will continue updating and I will make a guide with my Ryzen 3900X because now it performs just really good, a total beast.
#50678
cclau74 wrote:17h
hw.busfrequency: 96000000
hw.busfrequency_min: 96000000
hw.busfrequency_max: 96000000
hw.cpufrequency: 3794000000
hw.cpufrequency_min: 3794000000
hw.cpufrequency_max: 3794000000
hw.tbfrequency: 1000000000
machdep.tsc.frequency: 3800000000
15h_16h
hw.cpufrequency: 3793000000
hw.cpufrequency_min: 3793000000
hw.cpufrequency_max: 3793000000
machdep.tsc.frequency: 3743580002
CPU: RYZEN 3 2200G
More info..
17h : Video and Audio is perfectly sync. OpenCL: 64k
15h_16h: Video and Audio is out of sync. OpenCL: 115k
Using latest 17h
Geekbench 4: SC=4524, MC=13419
Open CL: 112k
Cinebench R20: 1511
Video and Audio is perfectly sync now.
Thanks. :)
#50808
I had the same issue. Vega 64 card, Ryzen 1700x, using the older 17h patches. Got 40k openCL score (I get 200k in windows).
Just discovered there were new patches yesterday. Everything runs fantastic now (video is smooth), and openCL score is 150k.
Nice work guys! I couldn't be happier!
#50892
FlexIDK wrote: Wed Jul 24, 2019 2:13 pm Confirm too. OpenGL app work with full performance with patсh 15_16h.
Thx!
Can you please upload your efi with config? I have similar components, or did you install just like on vanilla instructions? What about bios?
#50908
Bioraft wrote: Thu Aug 01, 2019 9:12 pm Wow I already tested the 15h_16h patches in Zen2 3900X with x570 mobo and yes the performance is quite better, but I had to make some changes to make it work, I have to add the algrey - cpu_topology_sort -disable _x86_validate_topology from the 17h patches to the old ones, and the machine booted up, without that no. And the performance is really good in 3D now, in games in all scenarios. And the processor performance is really good. But I think is just one kernel patch the problematic, because I was mixing some configs from one to the another and when I use one the 3D performance got really low. I will keep updated about my investigations. But until now, full Usb 3.1/3.2, native audio with AppleALC, a lot better graphics performance with VDAHardware support for encode/decode h.264/h.265, until now the performance is lot better than my Intel Hackintosh and I got it because of you people, I will continue updating and I will make a guide with my Ryzen 3900X because now it performs just really good, a total beast.
That's awesome news. When you make a guide please do link me - I'm genuinely thrilled to hear that you got this working properly.
#51200
Hey guys! The issue is still present even with the latest config for 17h on 18G95 build. I am going to try to use 15h_16 and report back
EDIT: Using 15h_16 prevented booting up entirely and even stopped me from opening up bios setup:) had to disconnect the drive to enter bios again .. I was following default instructions and setting Inject option in Devices to "No" as per some guide regarding not functioning AppleACL
I am attaching my working EFI that has the GPU performance issues (17h config)
(3.23 MiB) Downloaded 23 times
#51214
granolaboy wrote:I had the same issue. Vega 64 card, Ryzen 1700x, using the older 17h patches. Got 40k openCL score (I get 200k in windows).
Would be very kind if you could share your config.plist, because I've noticed no difference. My Vega still performs badly. Thank you!
#51220
Tried 15-16th vanilla patched for config.plist. not working for me, it caused reboot on Clover boot display [something I cant remember] +++++++++++++++++
attached my configs, config with _117th is working config.
y.aotsuki wrote: Sat Sep 21, 2019 6:12 am Tried 15-16th vanilla patched for config.plist. not working for me, it caused reboot on Clover boot display [something I cant remember] +++++++++++++++++
Forgot Cinebench score, just around 33k.
My bad...maybe this is ok?
(7.75 KiB) Downloaded 20 times
