by: Peartfan
#56767
Hello all~
I'm new here and was wondering if anyone could assist with Installing Catalina on an AMD platform? Running FX-8320 CPU, MSI 970A Krait Motherboard and AMD Raderon RX 580.
I have downloaded all the tools needed. I'm willing to work and learn or if you are feeling SUPER generous and want to build the EFI for me :thumbup: Can't seem to find a build guide for this setup.
Thanks in advance!
Cheers
Shane
Yes...I know I mispelled Radeon.....the wife was giving me dirty looks for spending a whole day on this! :lol:
by: ben higham
#56786
@Peartfan, im knocking at this same door mate. i have the same build pretty much, fx 8350 same gpu, but sabertooth 99FX r.2 so let me know if you get it up and running :):):) :thumbup:
im already on high sierra, but the EFI I have does not work for Cataina for some reason.
by: Peartfan
#56810
Ben,
I have been working on it. I may have a long hill to climb still. I'm new to Hackintosh and have been getting into deep water. I have found some good build guides for Ryzen series but the FX seems harder to find. For now I am running Catalina in a VM and I can live with that (unless someone replies that can hold my hand through the process ) until my next build. I will definitely change over to Intel chipset with gigabyte motherboard so I have a fighting chance. I did a hackintosh on my faithful Thinkpad using Clover and it wasn't too bad but this OpenCore stuff is beyond me. Good luck buddy and if you get to a point to help, give me a holler!
by: Dhaniekonugroho
#56820
Hi, I have the pretty similar setup
AMD FX 8350, Asrock 970 (same chipset)
and Sapphire Radeon RX580
I have a working EFI for my setup. You can try it and see how it goes. I use OpenCore 0.5.7 (the latest one as I wrote this).
Simply copy the EFI folder to your USB installation and we can go from there.
https://drive.google.com/open?id=1RZZ4e ... YvXzoBIrKd
Thanks
by: Peartfan
#56908
Thanks! I'll try your EFI. Do I have to load it into config.plist with propertree?
I tried following vanilla guide. Built my own EFI and config.plist
Getting "cs: failed to parse dict field of type 0
I'm new to hackintosh. Probably a stupid mistake but can't find any Info on the error.
Thanks SO much for the reply. Will keep at it
@Dhaniekonugroho, I didn't get the chance to download your EFI : It's in your "Trash" in google drive. Could you post it up again? Thanks Buddy!!!
by: spykor
#57049
Dhaniekonugroho wrote: Fri Apr 24, 2020 6:52 am Hi, I have the pretty similar setup
Thanks
Hey man, I tried to download the linked EFI file but I couldn't because it says that "The file is in owner's trash". Can you repost it? I have FX-6300 CPU on Gigabyte 990XA-UD3 mobo and I am having trouble with the installer (reach the Opencore menu but stuck there because I have no keyboard response).
I want to try you EFI to se if it works on my PC
thanks
