#55254
Hi everyone,
I am currently facing an issue where my Ryzentosh freezes in FCPX when rendering. Editing is no problem as long, as I don't need to render something (e.g. stabilizing footage is a Problem).
My setup:
CPU: Ryzen 3950x
MoBo: ROG 570x Gaming-F
GPU: Vega 64
(the system is running Stable under CPU/GPU load, no OC atm)
Now I am Searching for the reason why it is freezing, and read the Log from the console:
system.log
Mar  5 11:58:03 Ls-iMac-Pro Final Cut Pro[322]: notify name "com.apple.coregraphics.GUIConsoleSessionChanged" has been registered 20 times - this may be a leak
Mar  5 11:58:08 Ls-iMac-Pro Final Cut Pro[322]: DEPRECATED USE in libdispatch client: Clearing handler after the source has been activated; set a breakpoint on _dispatch_bug_deprecated to debug
Mar  5 11:58:08 Ls-iMac-Pro Final Cut Pro[322]: assertion failed: 18G103: libxpc.dylib + 90677 [7DEE2300-6D8E-3C00-9C63-E3E80D56B0C4]: 0x89
Mar  5 11:58:09 Ls-iMac-Pro Final Cut Pro[322]: BUG in libdispatch client: mach_recv, monitored resource vanished before the source cancel handler was invoked { 0x600002cab500[source], ident: 274947 / 0x43203, handler: 0x10861e430 }
An that is what the Mac analytics Data show:
11:58:03.603556 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.clients
com.apple.message.__source__: SPI
com.apple.message.architecture: 64
com.apple.message.context_type: GL
com.apple.message.signature2: 342230
com.apple.message.signature3: GL2
com.apple.message.intermediate_frameworks: AppKit,ProGL,Flexo,CoreFoundation,LunaKit,Direct
com.apple.message.signature1: com.apple.FinalCut
com.apple.message.summarize: YES
SenderMachUUID: A4AA8CB9-942B-3EC8-A3AE-37437FE5F17E
11:58:03.614023 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.clients
com.apple.message.intermediate_frameworks: Flexo,AppKit,LunaKit,Direct
11:58:03.625214 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.clients
com.apple.message.intermediate_frameworks: ProGL,Flexo,LunaKit,Direct
11:58:03.936986 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.clients
com.apple.message.intermediate_frameworks: ProGL,Flexo,AppKit,LunaKit
11:58:04.301567 +0100	Final Cut Pro	com.apple.message.domain: com.apple.finalcutpro.ui_language
com.apple.message.signature: de-DE
11:58:04.382146 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.clients
com.apple.message.intermediate_frameworks: QuartzCore,AppKit,CoreFoundation,HIToolbox,LunaKit,libdyld.dylib,<Unknown>
11:58:04.421152 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.GLfeatures
com.apple.message.signature2: 64
com.apple.message.signature3: dither
11:58:04.424618 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.clients
com.apple.message.intermediate_frameworks: QuartzCore,CoreVideo,libsystem_pthread.dylib
11:58:04.601201 +0100	Final Cut Pro	com.apple.message.domain: com.apple.finalcutpro.filesystem
com.apple.message.file_system: apfs
com.apple.message.is_internal: 1
com.apple.message.is_removable: 0
com.apple.message.supports_hardlink: 1
com.apple.message.supports_advisoryfilelocking: 1
com.apple.message.supports_filecloning: 1
com.apple.message.supports_persistentid: 1
com.apple.message.supports_symboliclink: 1
11:58:05.042923 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.clients
com.apple.message.intermediate_frameworks: Helium,Flexo,libdispatch.dylib,libobjc.A.dylib,Direct,Foundation,TLKit
11:58:05.043338 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.clients
com.apple.message.intermediate_frameworks: ProGL,Flexo,libdispatch.dylib,libobjc.A.dylib,Direct,Foundation,TLKit
11:58:05.050098 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.clients
11:58:05.050688 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.clients
com.apple.message.intermediate_frameworks: CoreVideo,Helium,Flexo,libdispatch.dylib,libobjc.A.dylib,Direct,Foundation
11:58:05.055366 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.GLfeatures
com.apple.message.signature3: 16bit_Depth
11:58:05.095858 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.GLfeatures
com.apple.message.signature3: 24bit_depth
11:58:05.164384 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.clients
com.apple.message.intermediate_frameworks: ProGL,Flexo,Foundation,libsystem_pthread.dylib
11:58:05.196908 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.clients
com.apple.message.intermediate_frameworks: Helium,Flexo,libdispatch.dylib,Foundation,libsystem_pthread.dylib
11:58:05.214588 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.clients
com.apple.message.intermediate_frameworks: Helium,Flexo,Foundation,libsystem_pthread.dylib
11:58:05.215473 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.clients
com.apple.message.intermediate_frameworks: CoreVideo,Helium,Flexo,Foundation,libsystem_pthread.dylib
11:58:05.262605 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.clients
com.apple.message.intermediate_frameworks: Helium,Flexo,CoreFoundation,Foundation,libsystem_pthread.dylib
11:58:05.283377 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.GLfeatures
com.apple.message.signature3: gl_fragment_program_arb
11:58:05.373066 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.clients
com.apple.message.intermediate_frameworks: ProGL,Flexo,libobjc.A.dylib,Helium,libsystem_pthread.dylib
11:58:06.869797 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.clients
com.apple.message.intermediate_frameworks: Helium,ProAppsFxSupport,Direct,CoreFoundation,Foundation,LunaKit,AppKit,Flexo
11:58:06.872908 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.clients
com.apple.message.intermediate_frameworks: Helium,ProAppsFxSupport,Direct,AppKit,Flexo,Foundation,CoreFoundation,HIToolbox,LunaKit,libdyld.dylib
11:58:06.874008 +0100	Final Cut Pro	com.apple.message.domain: com.apple.finalcutpro.filesystem
11:58:06.963233 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.clients
com.apple.message.intermediate_frameworks: QuartzCore,AppKit,Direct,Flexo
11:58:06.963560 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.clients
com.apple.message.intermediate_frameworks: QuartzCore,AppKit,libdispatch.dylib,libsystem_pthread.dylib
11:58:08.000000 +0100	kernel	com.apple.message.domain: com.apple.kernel.32bit_exec
com.apple.message.signature: Check32BitTool,Final Cut Pro,K36BKF7T3D,com.apple.Check32BitTool
11:58:08.918246 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.clients
com.apple.message.intermediate_frameworks: ProGL,Flexo,CoreFoundation,AppKit,LunaKit
11:58:08.947737 +0100	Unknown	com.apple.message.domain: com.apple.assumes.failure
com.apple.message.signature: 7DEE2300-6D8E-3C00-9C63-E3E80D56B0C4:90677
com.apple.message.signature2: 0x89
com.apple.message.signature3: libxpc.dylib
11:58:15.240811 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.clients
com.apple.message.intermediate_frameworks: ProGL,FxPlugProvider,Flexo,DeepSkyLite,CoreData,libdispatch.dylib,CoreFoundation
11:58:15.326773 +0100	Final Cut Pro	OSActivityID: 0x80000000000037f1
com.apple.message.intermediate_frameworks: Helium,ProAppsFxSupport,Direct,Flexo,AppKit,LunaKit,HIToolbox
11:58:16.363453 +0100	Final Cut Pro	OSActivityID: 0x80000000000037f1
com.apple.message.intermediate_frameworks: AppKit,ProGL,ProGraphics,Ozone,MotionEffect,Flexo,Foundation,libdispatch.dylib,libsystem_pthread.dylib
11:58:16.527882 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.clients
11:58:17.359470 +0100	Final Cut Pro	com.apple.message.domain: com.apple.graphics.clients
com.apple.message.intermediate_frameworks: AppKit,ProGL,ProGraphics,TextFramework,Helium
11:58:20.349343 +0100	Final Cut Pro	OSActivityID: 0x80000000000037f1
com.apple.message.intermediate_frameworks: AppKit,ProGL,ProGraphics,Ozone,TextFramework,Flexo,Foundation,libdispatch.dylib,libsystem_pthread.dylib
11:58:20.354022 +0100	Final Cut Pro	OSActivityID: 0x80000000000037f1
com.apple.message.intermediate_frameworks: ProGL,Lithium,ProGraphics,Ozone,TextFramework,Flexo,Foundation,libdispatch.dylib,libsystem_pthread.dylib
11:58:20.354321 +0100	Final Cut Pro	OSActivityID: 0x80000000000037f1
com.apple.message.intermediate_frameworks: Helium,Lithium,ProGraphics,Ozone,TextFramework,Flexo,Foundation,libdispatch.dylib,libsystem_pthread.dylib
11:58:20.354743 +0100	Final Cut Pro	OSActivityID: 0x80000000000037f1
com.apple.message.intermediate_frameworks: CoreVideo,Helium,Lithium,ProGraphics,Ozone,TextFramework,Flexo,Foundation,libdispatch.dylib,libsystem_pthread.dylib
So, is anybody facing issues with FCPX too? Has someone a idea how to fix it?
It seems to me like an issue with the graphics card/drivers. But I don't know why. In my previous build with an i7 6800k it was running fine with the Vega 64.
Help is very much appreciated!
By the way: Export seems to work, as long as there is no stabilisation involved. The perfomance is okayish.
BruceX: 25 Seconds
4k Video (6:27 min) export to 4k H.264 took 4:14 Seconds.
So it seems, that stabilisation is having trouble? :think:
#55257
What SMBios are you using?
#55309
iMacPro1,1 :eh:
