by: Howard LU
#54930
Hello,When I try to run MakeInstall.bat,I do as the guide did,but i stuck after I format my USB disk.
It told me "An error occurred:
Error opening input file: 3 ϵͳҲָ·
Press [enter] to return to the main menu...
I have tried using other disks but it still failed.
by: Mic87DT
#55509
I had another error, but if you are under Windows try to use it in "Save mode with internet connection". I solved in this way
