by: endroca
#50111
I can not install the macos on the SSD (suv300s37a240g), it is extremely slow
I tested it and installed it on a hard drive (Installation occurred normally)
Anybody have any suggestions?
tutorial used: viewtopic.php?f=59&t=4127
#50113
Have you ever had Windows on it? Was it the same there? Is TRIM enabled?
endroca liked this
by: endroca
#50114
I had linux on it, but I used the hdd low level format to clean it (I used dualboot linux-windows)
Did not use TRIM, should I activate it in the terminal?
After I activated TRIM the problem was solved.
Thank you so much!! :thumbup: :thumbup:
Shaneee liked this
by: Molly Duhig
#50285
AMD OS X is the registration forum to get the full access of the related type of the story in the good aspects. The installation and the post installation are the issues with assignmentexpert review by very slow SSD for them.
