by: thiagomenini
#47499
Hello,
I made a install of High Sierra 10.13.2 with the HighSierraAMD_V2 UEFI.dmg
Eveything its right, but not the boot. I install the Clover boot but it not apear when I restart the computer. I only boot with the USB from the dmg install.
I've tried different solutions: Format in FAT32 the EFI partition. Put the afps.efi archive into the UEFI64...
But I thing this might be a incompatibility with the ssd or something that i need to do to run the boot from the ssd drive
Anyone has this problem. I look in diferent foruns and have no answer.
Thanks for any help
by: Scath
#48147
Heya bud, I have a Sandisk SSD and had issues making it read the UEFI. I literally copied the entire EFI folder over to my partition as they say to do in the Post Install of the AMD High Sierra V3 installation thread. viewtopic.php?f=59&t=4127
This worked for me seemingly.
@felipelacerda , did you read my second edit? […]
Same problem my friend :problem: Have you the sh[…]
I sit with the same sleep problem, no USB issue[…]
You should not need the DSDT.aml nor the SSDT-EC[…]
