#55416
That's correct yes.
by: maxkopp
#55450
Hi again,
Sadly it did not help... I saw while booting up the message: Coulndt alloc class "NVmeFix"
Does that have something to do with it?
#55459
Remove the NVMEFix kext. It's not needed.
#55463
Did you add the SSDT to your config as well as the folder in OpenCore?
