by: tikizondo94
#54272
Thanks Shaneee :thumbup:
(921.46 KiB) Downloaded 37 times
#54274
Give this a go,
(732 Bytes) Downloaded 86 times
borob, tikizondo94 liked this
by: tikizondo94
#54293
Once again, You are the man Shaneee!. Works flawless. NVMe now shows as internal :thumbup:
Much appreciated. Thank you
Screen Shot 2020-02-01 at 12.33.58 PM.png (373.32 KiB) Viewed 202 times
Shaneee liked this
#54294
tikizondo94 wrote:Once again, You are the man Shaneee!. Works flawless. NVMe now shows as internal :thumbup:
No problem :thumbup:
by: tikizondo94
#55172
I've learned you can also add in OpenCore DeviceProperties/Devices within your NVMe PCI data add "built-in with a value of "01" with Type="Data". Also made my drive show as Internal :)
by: maxkopp
#55402
Shaneee wrote: Sat Feb 01, 2020 6:37 pm
Hi Shaneee,
Do you think it would be possible that you do this for me too?
Thanks a bunch!
#55403
Hi Shaneee,
Thanks a bunch!
You can use the same file.
#55411
I've found it to be generic so should work for you too.
