by: pi2in3
#50199
@Shaneee,
i tried, downloaded update and restarted to "Boot macOS Install From Ryzentosh"
but it dont continue to install and restarts :(
#50201
You used the patches for Zen correct?
by: pi2in3
#50202
Shaneee wrote:You used the patches for Zen correct?
i don't know what do you you mean about patchs, how can i check?
also in last 24hours i've been trying create Mojave vanilla installer USB witch i created and installed couple of months ago some times, but no success this time. i completely the problem is newer version of Clover installers. plz check it, i'm completely sure. (i wish i copied efi folder to somewhere :cry: )
@Shaneee,
would you just share your Mojave's whole EFI with me? our system is very similar to each-other.
#50207
Try with this config.
by: pi2in3
#50214
@Shaneee,
thnk you man. my mistake was adding some extra kext to EFi,, after deleting i installed macOS. every thing is fine except telegram and vlc. telegram is very slow and choppy also VLC has problem with mkv files.
both used to work well on 10.13.3
#50222
It may be related to the OPEMU. The Vanilla patches don’t include the OPEMU as we can’t include it via patches. With the compiled kernel it’s baked in.
#50225
That’s an option yes. You can rename the kernel once downloaded to kernel.amd then add the boot arg kcsuffix=amd to Clover to use it.
by: pi2in3
#50226
@Shaneee, i did it , no change. does Mojave similar issues? i'm gonna buy a used RX560 or RX570.
#50227
Mojave doesn’t have the Opemu either. Make sure Lilu is upto date and use the Native USB fix for Ryzen.
Hi there, Since my old graphics card is not compa[…]
I read the posts and just want to drop in with my […]
Hello I have this kind of hardware: AMD FX-8350 A[…]
Catalina 10.15.4 Update Bug?
Sorry no success that didn't´change anything[…]
