by: dhruvjit
#48152
Hi! I recently created a vanilla USB installer for macOS 10.13 High Sierra according to the instructions provided at vanilla.amd-osx.com
When I tried to boot into the installer, everything went fine and I even formatted the hard drive. But when I clicked continue at the "Reinstall macOS", it gave me an error stating "The recovery server could not be contacted."
I'm new to this Vanilla installer and do not know much about it, would appreciate some help.
NOTE1: I did not have an internet connection at the time of installing macOS; and I even checked that my date was not preceding the release of macOS High Sierra
NOTE2: If internet access is required, I am unable to get ethernet access, but I do have a wireless card (TP-Link TL WN823N); I also need to figure out a way to install the required drivers for my wireless card directly to the installer.
Thanks in advance.
#48160
Is that the USB adapter? You can try adding these two kexts into the Clover kext folder.
by: dhruvjit
#48175
Hi Shaneee! As for the kexts, I have placed them in my clover folder.
But my WiFi adapter requires a utility to connect to WiFi.
Without it I can't connect to any network. Is there anything which could be done to get the utility within the installer.
P.S.: I can't use ethernet, otherwise I would have done it with that. I am stuck with this USB adapter.
Thanks for your help
EDIT: I use the USB adapter drivers from https://tp-link.com/us/support/download ... 3n/#Driver and also for the vanilla install I use a patched StatusBarApp for 64-bit support (attached).
by: MacPiston
#48184
I'm facing the same problem - I need to use WiFi adapter due to OS X not seeing my Windows laptop sharing internet thru LAN. I have RTL8188SU based one, but your kexts haven't helped me. I assume that wifi should pop up in top right corner on main installation screen?
EDIT: I wonder if there is a possibility to download and copy to pendrive full macOS installer? Therefore internet connection shouldn't be more needed.
by: dhruvjit
#48186
MacPiston wrote:I'm facing the same problem - I need to use WiFi adapter due to OS X not seeing my Windows laptop sharing internet thru LAN. I have RTL8188SU based one, but your kexts haven't helped me. I assume that wifi should pop up in top right corner on main installation screen?
I have a WiFi adapter with the RTL8192EU chipset (TP-Link TL-WN823N) and I need a utility provided with the installer pkg in order to connect to WiFi networks
by: MacPiston
#48188
I know, but I wonder if there is a kext/way to enable this adapter in "native" way so macOS will use inbuilt WiFi network selecting etc
#48189
Okay, I found my problem. Actually I was missing the SharedSupport files in the installer made by gibMacOS, so I built a custom installer and it worked.
As for the WiFi adapter @MacPiston, I too wonder if we might get a native support.
Cheers! :thumbup:
by: MacPiston
#48190
Have you downloaded full set of files? Or enabled recovery only? I wonder also why when I download full set it still want me to connect to internet... :roll:
Install mojave from 0 (first time)
Hi, I would like to do my first Rayzen-Hackintosh […]
Cerisea Medica The preventative results exercis[…]
High Sierra 10.13.6 installer
1533mhz * 2 (dual channel) = 3066 mhz. that's abo[…]
