#38041
You need your V2 installer handy for this.
Let the App Store download the update and let it run the first part of the install and reboot
On Reboot, boot from USB Installer to Boot macOS from HighSierraAMD and run preinstall command
On Reboot, boot from USB Installer to Boot Install from YOURDRIVENAME and let install run and reboot
On Reboot, boot from USB Installer to Boot macOS from HighSierraAMD and run amd command and reboot
On Reboot, boot from YOUR Clover installation to your hard drive for the last part of the installation.
#38058
:thumbup: I'll try this when I get home.
Will this resolve laggy performance?
I've just completed a fresh 10.13.2 install.
#38709
Ok, next on the to do list. So I assume that all the updates we'll need to follow this procedure :?:
#38713
RagingDemon wrote: Wed Mar 07, 2018 2:45 am Ok, next on the to do list. So I assume that all the updates we'll need to follow this procedure :?:
Can someone confirm this? If so, that will be fantastic.
#38714
Well I can at least confirm that I needed to do this for this update. Mind you it was a lot faster. :thumbup:
#38715
RagingDemon wrote: Wed Mar 07, 2018 5:07 am Well I can at least confirm that I needed to do this for this update. Mind you it was a lot faster. :thumbup:
Just finished upgrading, very smooth experience, and I do need to uninstall the stale NVIDIA driver and install the new one.
#38716
Just install the new one. I don't think you need to uninstall the old one.
#38725
RagingDemon wrote: Wed Mar 07, 2018 7:20 am Just install the new one. I don't think you need to uninstall the old one.
I see. I was trying to play safe, but next time I would just instal the new one.
#39241
preinstall fails to do its job
on reboot I get no Boot Install FROMMYHARDDRIVE
I just get Boot options including my hard drive.
Using HighSierraAMD V2
