#37959
Alright. I'm trying it now.
#37961
Wow. I got to the installer screen! Guess that's what to do if that happens again.
#37976
It successfully updated! Thanks for everything! :thumbup:
#38028
Thanks for the guide it worked perfectly I ran through it twice since to install the supplemental update as well. However I'm having an issue when running my main system which sometimes restarts(maybe from powernap?) and boots to the install update partition instead of the main partition. Is there a way to disable/delete these partitions?
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
