#37457
You need your V2 installer handy for this.
Let the App Store download the update and let it run the first part of the install and reboot
On Reboot, boot from USB Installer to Boot macOS from HighSierraAMD and run preinstall command
On Reboot, boot from USB Installer to Boot Install from YOURDRIVENAME and let install run and reboot
On Reboot, boot from USB Installer to Boot macOS from HighSierraAMD and run amd command and reboot
On Reboot, boot from YOUR Clover installation to your hard drive.
marinel, A H W, WillETC and 5 others liked this
#37569
I am getting a backtrace error on the boot after preinstall.
#37610
5fusion wrote:can i update from 10.13.1 to 13.3 using xlnc v2 installer?
You would need to ask XLNC I only support the HighSierraAMD Official.
chasekap13 wrote:I am getting a backtrace error on the boot after preinstall.
Try running preinstall again and booting from Boot macOS from Install YOURDRIVE.
#37627
Unfortunately, that's what I did so far. It didn't work. :D
  • 1
  • 2
  • 3
  • 4
  • 5
  • 7
