by: roma isaev
#53975
Good afternoon, I would like to contact you for help, I have a problem installing mac os on wmware, I made a lot of attempts at installation and once I succeeded, but after the blue screen of the host’s death, the virtual machine crashed, my further installation attempts ended failure, even following the instructions thanks to which I had previously installed a working virtual machine. At the moment I was trying to install mac os mojave on vmware player, according to the instructions in vmx you need to insert smc.version = "0" and the cpu mask. But after these actions, the virtual machine does not even start, if you do not do these instructions, the guest OC will turn off the processor, I hope for your help, thanks.
Logs provided and more virtualization is enabled)
(14.11 KiB) Downloaded 29 times
Снимок экрана (73).png (290.47 KiB) Viewed 324 times
