by: donaldp
#7275
I'm having a lot of issues with downloads in this machine. I can go and download the same file in Windows and have no problems at all. Unfortunately then copying it across to the VM sometimes works and sometimes doesn't (as in the copy itself works, but then the imported file doesn't work for some reason, sending me back to square one). Any ideas why downloading is so problematic and what I can do to fix it? See pic for some examples of this behaviour...
by: Valkiry
#7276
Set up a FTP server and transfer files that way?
#7280
Check the network settings of the VM match your system.
by: donaldp
#7301
Shaneee wrote:Check the network settings of the VM match your system.
Hadn't thought to look at that (new to both OSX and VM's, so can be a bit "deer in the headlight" type stuff going on ;-) ), and when I did I saw a checkbox saying "replicate physical network connection state" - let's tick that and see what happens, and voila(!), downloading like a boss now. :-) Thanks!
by: donaldp
#7302
Valkiry wrote:Set up a FTP server and transfer files that way?
The issue there is auto-installer doing the downloading directly. Fortunately the issue is fixed now anyway, but thanks for the suggestion.
by: donaldp
#7308
Took a bit more fiddling, but got there in the end. Happy man. :-)
by: mv93
#7859
Benhu wrote:Hi there, I'm getting stuck on VM Swap Subsystem is ON. Any ideas? Thanks
no one ?? i'm with same problem
#7860
You've already made a support topic to which I've replied to...
by: kostas22
#8578
Hello guys , i need some help. If i update the vm-image through app-store and replace the kermel via maping the virtual disk, vmware still says that my virtual CPU was enter the shutdown state, any ideas ?
#8579
You'll need to boot without the caches. UseKernelCache=No
  • 1
  • 5
  • 6
  • 7
  • 8
  • 9
  • 10
