#4412
The security update replaces the kernel... You'll either need to attach an installer to replace it or download it again.
by: OSXF
#4422
Shaneee wrote:The security update replaces the kernel... You'll either need to attach an installer to replace it or download it again.
How to do that through installer?
#4423
You'd need to use my Windows image restored to a USB with the Yosemite kernel placed on the root and use Terminal to copy it back into the VM. You're better off installing physically though. Much better performance.
by: Shadow
#6088
WOW! It Works. Without any problems :thumbup:
before that i tried techsviewer.com - no result. lost time.
Thank You!
by: Shadow
#6153
Would be great, if in future assemblies you will switch on option 'Show Connected servers on Desktop' in Finder. It's very useful when using Shared Folders in VmWare.
#6530
See the screenshot to download. Once downloaded double click the .vmx file to open it in VMWare.
by: donaldp
#7127
Shaneee wrote:@OSXF, Fromt he VMWare website,
To increase the svga.vramSize setting:
  1. Power off the virtual machine.
  2. Right-click on the virtual machine and select Edit Settings.
  3. Click the Hardware tab.
  4. Click Video Card.
  5. Select Enter total video RAM and enter a higher value.
  6. Click OK.
  7. Power on the virtual machine.
I'm still trying to get something >=10.10.4 working on my machine (best I've managed so far is 10.10). I am now trying this one (as if it works will be simpler than the extensive directions for upgrading 10.10). When I start it up it just hangs (see pic). When I click on the screen my pointer disappears (thought maybe I have to click on which one I want to start?). I've downloaded VMware Workstation 12.5.0 build-4352439, and it isn't giving me the option to increase video memory (see pic), which was the first thing I thought to look at. Don't know what else to try. I have an FX-4300.
#7142
You click into the VM then press enter to boot the system. Once it's booted if you press Ctrl + Alt + Return the VM should go full screen and give you full resolution.
by: donaldp
#7271
Shaneee wrote:You click into the VM then press enter to boot the system. Once it's booted if you press Ctrl + Alt + Return the VM should go full screen and give you full resolution.
Yep, that was the piece of info that I was missing. Thanks!
  • 1
  • 4
  • 5
  • 6
  • 7
  • 8
  • 10
