#37863
Download Oracle's VirtualBox 5.2 from here:
http://virtualbox.org
Download the macOS10.13.2.vmdk here:
http://bit.ly/10_13_2VM
Create a new VM called macOS and configure your settings like so:
Once setup is complete, exit VirtualBox and open a Command Prompt with Administrator Privileges. Now copy and paste the following commands into your Command Prompt.
cd "C:\Program Files\Oracle\VirtualBox\"
VBoxManage modifyvm "macOS" --cpuidset 00000001 000106e5 00100800 0098e3fd bfebfbff
VBoxManage setextradata "macOS" "VBoxInternal/Devices/efi/0/Config/DmiSystemProduct" "MacPro6,1"
VBoxManage setextradata "macOS" "VBoxInternal/Devices/efi/0/Config/DmiSystemVersion" "1.0"
VBoxManage setextradata "macOS" "VBoxInternal/Devices/efi/0/Config/DmiBoardProduct" "Iloveapple"
VBoxManage setextradata "macOS" "VBoxInternal/Devices/smc/0/Config/DeviceKey" "ourhardworkbythesewordsguardedpleasedontsteal(c)AppleComputerInc"
VBoxManage setextradata "macOS" "VBoxInternal/Devices/smc/0/Config/GetKeyFromRealSMC" 1
VBoxManage setextradata "macOS" VBoxInternal2/EfiGopMode 5
VBoxManage setextradata "macOS" VBoxInternal2/EfiGraphicsResolution 1920x1080
VBoxManage setextradata "macOS" "VBoxInternal/Devices/efi/0/LUN#0/Config/PermanentSave" 1
Now close the Command Prompt and reopen VirtualBox.
http://bit.ly/2IZjtfq
And do the following commands from an Administrator Command Prompt:
VBoxManage.exe modifyvm "macOS" --cpuidset 00000001 000106e5 00100800 0098e3fd bfebfbff
VBoxManage setextradata "macOS" VBoxInternal2/EfiGraphicsResolution 1280x1024
You need to do these steps the first time you start the VM, once configured it will save the changes permanentl. The only time you need to run through setting up EFI, is after doing an update.
Start the macOS VM and immediately begin pressing F2 to enter the UEFI Boot Maintenance Manager. Once you enter you will see the following screen:
Highlight Boot Maintenance Manager and press enter. Then select Boot Options and press enter.
Next select Add Boot Option and press enter.
Select the EFI entry and press enter.
Select EFI again and press enter.
Select Clover and press enter.
And finally Select CloverX64.efi.
Highlight the name field and press enter. Input the name of Clover for the Boot Entry and press return. Then arrow down to Commit Changes and Exit and press enter.
Select Change Boot Order and press enter.
Select Change the Order and then highlight Clover.
Move Clover by pressing the + sign to the top of the list.
Now Press F10 to save changes to the boot order.
Arrow to Return to Main Page and press enter. Then arrow down to Reset System and press enter to restart. You should be greeted with the main Clover Bootloader screen. Press enter to Boot the default entry into macOS.
From within the VM download Clover Configurator, once its downloaded launch it.
Once you've generated a new serial number restart so clover will load with it. Then try logging into iCloud.
While the VM is shutdown, edit the settings like so:
When the VM is running you'll see a spinning wheel, in the lower menu. Click it to stop recording or start recording.
Download HighSierraAMD installer from here and add it as a secondary drive to your VM:
High Res
http://bit.ly/10_13_2Install
Low Res
http://bit.ly/10_13_2Installb
From inside the VM open your web browser and go to:
https://support.apple.com/kb/dl1953?locale=en_US
From within the VM download the Combo Update.
Once the software is downloaded, double click the dmg to mount it. It will open and show you the combo update package. Double click on it to start the install process. Once it's done with the initial install, it will reboot. It will reboot to an install window. Let it run till complete, it will try to reboot but VBox doesn't reboot automatically, then choose Machine menu and from there click Reset. Begin pressing F2 immediately, as the install changed the boot order, to enter the UEFI Boot Maintenance Manager.
Move Clover back to the top of the list with the + key and save and restart.
At the Clover Boot menu you want to select the last entry, this is the HighSierraAMD installer. Press enter to boot it.
Once the installer loads, select you language and click Next. Then click on Utilities and then click on Terminal to open a terminal window. Enter the following in the terminal window:
cd /Volumes/HighSierraAMD
preinstall
enter macOS for the Volume Name
Once complete choose restart and once the machine hangs on reboot. Open Machine menu and choose reset. Once reset it will load the Clover Boot menu, select the Boot macOS Install from HFS+ volume entry to boot into the actual full install.
Once the installer finishes, it will try to reboot but hang. Click on Machine Menu and then choose Reset. Upon reset start pressing F2 to enter the Boot Maintenance Manager again to move Clover back to the top of the boot priority. Once done choose Reset System to restart to Clover.
Once the Clover Boot menu loads, you want to select the last entry again for the HighSierraAMD installer. Now we're going to do post install. Once the installer loads, select your language and click Next, then from the Utilities Menu choose Terminal. Once terminal loads you want to enter the following commands:
amd
enter macOS as the Volume Name
Once its done it will try to restart and hang, click on Machine Menu and choose Reset to boot to Clover. Now choose the first entry in the boot menu to boot macOS into your newly minted 10.13.3.
You can now remove the hsinstaller.vmdk from your list of drives and return to just having macOS and Recovery entries in Clover.
