by: mushkin
#54641
I've followed this tutorial step by step for making a virtual machine for my Ryzen system https://kb.amd-osx.com/guides/vmware/ and when i try to add the lines of code in to mask cpuid and to just even add bios bootdelay is comes up with an error when starting the virtual machine: "Error while opening the virtual machine: VMX file is corrupt"
it doesn't matter which line of code is added both of them comes up with the same error. Please help.
https://gyazo.com/904bb982ad701375fcba9f27abd8b724
by: gwehga
#54655
I have the same processor as you,and i have followed the same tutorial before. I didn‘t meet your problem.
But i got a 'CPU is disabled' error in the step of "installing macOS". Didn't know how to fix it.
by: ryzen0800
#55693
mushkin wrote:I've followed this tutorial step by step for making a virtual machine for my Ryzen system https://kb.amd-osx.com/guides/vmware/ and when i try to add the lines of code in to mask cpuid and to just even add bios bootdelay is comes up with an error when starting the virtual machine: "Error while opening the virtual machine: VMX file is corrupt"
Let scroll up to the file, you may see these two lines already in the file, just edit it instead.
by: open_command0
#55965
I had the same problem. It helped deinstalling Unlocker, installing it again, rebooting the system, formating the Drive (I'm using an external drive for my VM) and then installing the VM new in VM-Player just as the instructions says. Now it works like a charm
