#44116
Hi all,
Been a long time, but finally back to this task.
Tried a newer version than when I was last here, that being 10.12.6, and all worked first go! Very pleased. The final bit I need to start using it though isn't working, which is getting Xcode installed. The message is completely unhelpful, so does anyone have any ideas as to what to look at to try and resolve this? note: I have minimal Mac experience, so please spell out the exact steps needed. Thanks :-)
Looks like I found the problem - is there a way to increase the size of the disk (happy to re-install if needed), or do I need to add another one? It says that space is dynamically allocated - doesn't that mean it should add more if needed? Because obviously it isn't.
