by: Fumblemore
#21063
vitorlage wrote: Sat Jun 03, 2017 6:24 pm @Fumblemore, If it doesn't boot Clover is because Clover has not installed bootloader (boot0af).
Mount EFI partition, delete the content, empty Trash, rerun Clover installation again.
Don't forget to replace the config.plist by the one I posted
Alright doing that now :)
And btw, I get the iconic "... clover just booted legacy, trying to boot from hdd now.
EDIT: It booted (imagine that was in caps) Thanks pal, very much. Now, I hate to be a pain in the.. but do you know of any tutorials I could use to setup my gpu?
by: vitorlage
#21067
@Fumblemore, I know that if you put it to work you gonna be real close from the Nobel prize :lol:
Look here:
https://www.tonymacx86.com/forums/sierra-laptop-guides.189/
by: Fumblemore
#21070
vitorlage wrote: Sat Jun 03, 2017 6:41 pm @Fumblemore, I know that if you put it to work you gonna be real close from the Nobel prize :lol:
Look here:
Haha, you're very close to the good samaritan award. And I honestly can't thank you enough.
Oh, and I think I forgot to mention the GPU is an AMD HD 8280 (almost undocumented) / ATI R3 . So, the laptop guides are for a bit more advanced GPUs than the GPU I've got. I actually cannot find literally any documentation of an attempt to use it with a hackintosh, so umm, how would I attempt this?
#21084
Integrated AMD GPUs tend not to work but you can try this with Clover,
http://www.insanelymac.com/forum/topic/291117-how-to-make-radeon-desktop-or-mobility-be-working-by-using-clover/
Fumblemore liked this
by: Fumblemore
#21105
Shaneee wrote:Integrated AMD GPUs tend not to work but you can try this with Clover,
vitorlage wrote: Sat Jun 03, 2017 7:00 pm @Fumblemore, I'll try to find something then I tell you my findings.
Thanks pals, I'll check out that link in the morning, currently entertaining middle aged guests with Playstation VR (Hilarious) :)
#21345
Keep us updated.
by: Fumblemore
#21935
Shaneee wrote: Wed Jun 07, 2017 12:18 pmKeep us updated.
Sorry for the incredibly late reply. The post you sent didn't work, but I found a guy named 'spakk' on another forum who had success with a HD 8200 series, and he has sent me a link that he followed - which entails flashing the vbios.
#22022
I know Spakk well. If he has suggested it then give it a go :thumbup:
by: Fumblemore
#22060
Shaneee wrote: Mon Jun 12, 2017 7:48 pm I know Spakk well. If he has suggested it then give it a go :thumbup:
Great! I’m going to be attempting it, I just have an issue (which I can fix fine, hopefully). On my windows HDD I get the BSoD error whenever I try to boot, so I’m going to have to sacrifice a USB so that I can boot a recovery drive.
  • 1
  • 4
  • 5
  • 6
  • 7
  • 8
