by: Fumblemore
#21018
vitorlage wrote: Sat Jun 03, 2017 2:06 pm @Fumblemore, So now, you're booting in Legacy.... right?
.. UEFI, why? Should I be in legacy?
by: vitorlage
#21019
@Fumblemore, Of course, cause you have installed in EFI boot0af remember ? That's why you only see the +++++++++++++++++++++ and it restarts (no bootloader)
by: Fumblemore
#21020
vitorlage wrote: Sat Jun 03, 2017 2:19 pm @Fumblemore, Of course, cause you have installed in EFI boot0af remember ? That's why you only see the +++++++++++++++++++++ and it restarts (no bootloader)
Right, well umm I booted with these args (in legacy) "-v -no_compat_check ncpi=0x3000 nv_disable=1 cpus=1 dart=0" and it hangs again at PCI configuration begin grr
by: vitorlage
#21025
@Fumblemore, Lol. I was forgetting you're booting with Clover already, so that flags doesn't work and you're stuck at PCI config because you haven't edited your config.plist yet, and checked the npci=0x2000.
Solution: Boot trough USB Installer like you have done to install Clover
Then Download Clover Configurator, open it, Mount EFI partition and inside EFI/EFI/CLOVER/ replace the config.plist with this one.
(4.9 KiB) Downloaded 17 times
Fumblemore liked this
by: Fumblemore
#21027
vitorlage wrote: Sat Jun 03, 2017 2:38 pm @Fumblemore, Lol. I was forgetting you're booting with Clover already, so that flags doesn't work and you're stuck at PCI config because you haven't edited your config.plist yet, and checked the npci=0x2000.
Haha alright thanks pal, I'll test my tethering ;P
by: Fumblemore
#21049
Alright sorry for the late reply, I just tried your plist and it hangs at the plus signs :/
by: Fumblemore
#21060
vitorlage wrote: Sat Jun 03, 2017 6:04 pm @Fumblemore, Have you booted in Legacy mode ??
Righto, legacy won't boot clover. Just an underscore...
by: vitorlage
#21061
@Fumblemore, If it doesn't boot Clover is because Clover has not installed bootloader (boot0af).
Mount EFI partition, delete the content, empty Trash, rerun Clover installation again.
Don't forget to replace the config.plist by the one I posted
  • 1
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
