by: vitorlage
#20906
@Fumblemore, Can't you boot trough your USB Installer ? The same USB you installed Sierra ?
#20926
Did you get it installed? Formatting the drive with Windows won't work. You need to format with Disk Utility in the macOS installer.
by: Fumblemore
#20939
vitorlage wrote: Fri Jun 02, 2017 6:45 pm @Fumblemore, Can't you boot trough your USB Installer ? The same USB you installed Sierra ?
Very true. I was trying to use single user mode but not succeeding. Just if I would have figured out that there was a second page earlier :roll: .
Actually, I take that back. Terminal got me the same result as single user mode, oh well. I've attached the photo of it. Let me know if I need to be inside of a specific folder.
Shaneee wrote:Did you get it installed? Formatting the drive with Windows won't work. You need to format with Disk Utility in the macOS installer.
Yeah it's installed. Sorry if my post wasn't very clear, I did use disk utility to format. My issue is with getting clover installed :).
#20941
The actual Clover Installer fails then? Post the installer log.
by: Fumblemore
#20944
Yep. I have attached the log, although it seems to be the legacy log (that installed fine but doesn't boot), I did run the EFI install again but it didn't change the log.
by: Fumblemore
#20945
No button again..
#20946
Seems like it installed from that.
by: Fumblemore
#20947
Shaneee wrote: Fri Jun 02, 2017 8:53 pm Seems like it installed from that.
Exactly, but the installer itself shows failed.
And there are no boot options for UEFI. And legacy mode shows merely an underscore.
#20948
Install Legacy with these options,
by: Fumblemore
#20949
Shaneee wrote: Fri Jun 02, 2017 9:03 pm Install Legacy with these options,
Those are the options I choose when the installer throws an error.
  • 1
  • 2
  • 3
  • 4
  • 5
  • 8
