#19798
DiegoPaidjo wrote:
Shaneee wrote: Sat May 20, 2017 7:18 pm It's already in the Controller kext. @DiegoPaidjo, how did you install them?
i just drag an drop files from @vitorlage, with kext uttility, and rebuild prelinkkernel.
im setting igpu as primary gpu on bios.
this is wrong ?
That is right and if it has a auto option even better.
You have to boot with your internal card and then switch the cable to the external.
#19808
vitorlage wrote: Sun May 21, 2017 8:44 am That is right and if it has a auto option even better.
im setting the bios to auto,
yes i did it,but when cable connected to ext card display has no signal.
#19819
vitorlage wrote:@DiegoPaidjo, When you boot with the internal card what is the last messages you see? If you can post a picture
this is the pictures:
sowing me,
blaclist.controller : ATI venID  : 1002, DevID : aaf0
ATI venID  : 1002, DevID : 1300
WhatsApp Image 2017-05-21 at 17.38.20.jpeg (84.72 KiB) Viewed 226 times
WhatsApp Image 2017-05-21 at 17.38.20 (1).jpeg (69.6 KiB) Viewed 226 times
#19822
vitorlage, nothing difference before i did, after boot switch cable to ext gpu and still no signal.
#19825
DiegoPaidjo wrote:vitorlage, nothing difference before i did, after boot switch cable to ext gpu and still no signal.
Ok. Let's try another shot.
Just remove AMD9510Controller.kext and AMDRadeonX4100.kext from S/L/E
Run Kext Utility to repair permissions
Now add the one I sent you attached to Kext Utility
Wait until Kext Utility finishes, then Restart
Be prepared to boot blind
Connect the video cable to your RX 570 and try to boot in the dark (probably you may try to change BIOS settings - Primary Video device to PCI/PCIE
Try this and let me know
(3.21 MiB) Downloaded 18 times
#19829
@vitorlage,
Thank you vitorlage, you spent your time for helping me.
this is result of my last steps.
1. in osx, delete AMD9510Controller.kext and AMDRadeonX4100.kext from S/L/E with drag and drop into trash.
2. open kextutilitty repair permission
3. drag and drop new kext AMDRadeonX4100.kext and rebuild cache again in kextutilitty
4. restart, setting primary to ext card in bios (also i try setting in igpu)
5. result still no luck :(
so i try to using clover to inject this card with clover config.
my system cant boot, this is my last capture after setting clover ?
and i need to reinstall osx again :wtf:
Update :
i have to install again .
but, im not install bootloader yet.
after first boot, i install kext from vitorlage .
i have little change, in about my osx show up RX470 and R7 on detail grahics card, but VRAM still 3mb.
Can you explain in this thread ?
what tools/app I need to edit kext ?
https://www.tonymacx86.com/threads/enable-all-cores-r9-fury-cards.209892/
Screen Shot 2017-05-22 at 3.45.37 AM.png (122.92 KiB) Viewed 217 times
Screen Shot 2017-05-22 at 3.44.57 AM.png (1.02 MiB) Viewed 217 times
WhatsApp Image 2017-05-21 at 20.06.58.jpeg (38.49 KiB) Viewed 217 times
#19832
That last image is normal use bootflag -no_compat_check
Now I've realised you have Sierra 10.12.4, so you do need to install AMD9510Controller.kext too
I thought that you're using Niresh Zone which is 10.12.3
So drag and drop it in Kext Utility like the other one
#19846
@vitorlage, yes im using SierraAMD from shaneee, trying several times no changes i get.
i have resolution change to 1366x768 . but vram still no change, and i wonder about menu bar doesnt show icon, this is cause of graphics card or something else ?
Screen Shot 2017-05-22 at 5.25.52 AM.png (1.04 MiB) Viewed 212 times
