#19580
Hello again :wave:
I want to say thank you, finnally i get installed osx sierra.
I use 2 kind of sierra image
  1. Sierra Zone
    • bootflag : -v kcsuffix=amd npci=0x2000
    • Normal process installation but error in ending of installation process with OSInstall.postinstall.pkg (FIx by PostInstall steps from Shaneee :thumbup: )
    • Any Customize Kext before install process, bootloader etc
This is About Mac SierraZone :
  • SierraAMD V3 from shaneee
    • bootflag : -v npci=0x2000 USBBusFix=yes
    • PS2 Keyboard not working (FIx by Switch to USB Keyboard :D : )
This is About Mac Sierra AMD v3 :
Take screenshoot soon
Installed OSX with no graphics kext loaded, i have internal GPU R7 Graphics from APU and GPU ext MSI RX570.
can both work with kext ?
Here detail of my Graphics :
Image Image
Some detail from Catalyst Software
Thanks for your helps.
Sundhar88 liked this
#19582
On the zip goes modified AMD9510Controller.kext and AMDRadeonX4100.kext plus Kext Utility to install them and rebuild permissions.
Restart
Then in your BIOS if possible enable IGFX/IGPU to automatic or booting trough your integrated card the R7
Let me know if it worked
(4.34 MiB) Downloaded 57 times
DiegoPaidjo liked this
#19600
With the modified kexts in place and the prelinkedkernel rebuilt with them boot with the cable connected to the iGPU and once booted swap the cable to the RX card.
#19655
@vitorlage, Thanks for your help, buat still not working. I tried several times installing kext and rebuild cache still no luck.
@Shaneee, Thanks for answering my problem again, but need more effort :) , i have to delete prelinkedkernel and rebuild again still not working, used primary vga port or gpu port, my graphics still bad
this is capture my osx after instaling kext :
Screen Shot 2017-05-20 at 11.31.11 PM.png (114.84 KiB) Viewed 511 times
Screen Shot 2017-05-20 at 11.30.50 PM.png (19.7 KiB) Viewed 511 times
Screen Shot 2017-05-20 at 11.30.36 PM.png (39.14 KiB) Viewed 511 times
Screen Shot 2017-05-20 at 11.25.52 PM.png (34.04 KiB) Viewed 511 times
Screen Shot 2017-05-20 at 11.18.11 PM.png (888.22 KiB) Viewed 511 times
vitorlage liked this
#19658
DiegoPaidjo wrote:@vitorlage, Thanks for your help, buat still not working. I tried several times installing kext and rebuild cache still no luck.
I see no capture......
#19663
@vitorlage, sorry for my capture, i get hard when read my photos from osx, because in windows cant opened,
kextcache -u /my Volume
Screen Shot 2017-05-20 at 11.22.14 PM.png (220.43 KiB) Viewed 509 times
#19727
@vitorlage, Did you add the ID 0x67DF1002 to AMDRadeonX4100.kext ? The other kext doesn't need modified.
#19743
It's already in the Controller kext. @DiegoPaidjo, how did you install them?
#19783
Shaneee wrote: Sat May 20, 2017 7:18 pm It's already in the Controller kext. @DiegoPaidjo, how did you install them?
i just drag an drop files from @vitorlage, with kext uttility, and rebuild prelinkkernel.
im setting igpu as primary gpu on bios.
this is wrong ?
