#23596
@rolyf20 did you install the kext with Kext Utility?
Use the following kext and use this utility:
 http://mac.softpedia.com/get/System-Utilities/Kext-Utility.shtml
(126.93 KiB) Downloaded 21 times
by: inan
#51297
Shaneee wrote:Install this kext with Kext Utility and reboot,
Can you reupload this kext please, I think the package is damage.
Thanks
#51306
Thanks
Think this is the correct one,
(5.71 MiB) Downloaded 21 times
