by: Maurisiwi
#18618
Hello, my question is if this network card could work on OSX 10.12.4, since I have installed it on my pc but I do not recognize it. Is there any kext for this model? Try to put a kext running on yosemite but crash :cry:
I hope you can help me, thank you!
#18656
Install this kext with Kext Utility and reboot,
(5.73 MiB) Downloaded 72 times
#18744
It works very well! Thank you
#18776
Glad that sorted it :thumbup:
by: oridav
#20867
Hello!
I've installed the PlugIns and now Mac recognises wifi in the network connections but says the hardware it's not installed, and it is installed. Any explanation?
Thanks!
El Capitan 10.11.6
GIGABYTE Z170-HD3P ATX LGA1151-DDR4-3.0
CPU I5 7500 3.4GHZ 6MB LGA1151 QUADCORE
#20925
oridav wrote:Hello!
Thanks!
El Capitan 10.11.6
What's the Wifi device?
by: oridav
#21928
Hi Shanee,
Wi-fi device is tp-link wn881nd ->
https://www.pccomponentes.com/tp-link-tl-wn881nd-300mbs-11n-wireless-pci-express?gclid=CjwKEAjw1PPJBRDq9dGHivbXmhcSJAATZd_BfISc59B22RtdJ7-vOsqoGSZqM9NrBWtPLTVNDyqyNxoCuQfw_wcB
- I've been struggling with this several weeks. I've followed indications to insert "<string> pci168c, 2e </string>" on /System/Library/Extensions/IO80211Family.kext/Contents/PlugIns/AirportAtheros40.kext/Contents/Info.plist
- DId so. Download DPCImanager and rebuilt caches and repair permissions. For one day I got wifi, and the next one appeared "wi-fi: hardware not installed"
Thanks for the reply
El Capitan 10.11.6
Captura de pantalla 2017-06-11 a las 18.27.54.png (68.12 KiB) Viewed 336 times
Captura de pantalla 2017-06-11 a las 18.27.34.png (17.34 KiB) Viewed 336 times
Captura de pantalla 2017-06-11 a las 18.28.43.png (192.55 KiB) Viewed 336 times
Last edited by Shaneee on Mon Jun 12, 2017 7:45 pm, edited 1 time in total. Reason: link Coded.
#22021
Copy the kext onto you Desktop and download Kext Utility. Then drag the kext onto the app icon. This will install the kext correctly. Repair permissions and rebuild the caches.
by: oridav
#22179
Thanks a lot! It works now! :D :D :D
Shaneee liked this
