#51901
So I've been able to get to the recovery ultility screen but when I go to install sierra it gives me the "Recovery Server Could Not Be Contacted" message. I installed "RealtekRTL8111.kext" that worked for me last time on my mojave install to get my ethernet working. What am I doing wrong?
Ryzen 7 1700
16gb ram
Nvidia GTX 1060
Prime X370-PRO
#51903
Use this version. It's been fixed for the error in Clover, https://www.dropbox.com/s/fmdjt4z2objkt ... t.zip?dl=0
#51910
I used that version just now and still says "Recovery Server Could Not Be Contacted"
Shaneee wrote:Use this version. It's been fixed for the error in Clover, https://www.dropbox.com/s/fmdjt4z2objkt ... t.zip?dl=0
I used it but still is giving me the "Recovery Server Could Not Be Contacted"
You are using the wrong kext. Your chip is intel not realtek.
https://www.asus.com/Motherboards/PRIME ... fications/
LAN: Intel® I211-AT, 1 x Gigabit LAN Controller(s)
You can try this: https://www.tonymacx86.com/resources/appleigb.323/
From the following post: viewtopic.php?t=1277
Can´t find the edit post button, here is the original post:
https://www.insanelymac.com/forum/topic ... leigbkext/
And direct download link:
https://sourceforge.net/projects/osx86d ... stdownload
Or you can make an installer with the full High Sierra version, not just the recovery (about 4 GB).
