by: PokeRio
#50162
So I already install Sierra 10.12.6, all works perfectly except the nvidia graphics card wich is the GTX 1050 2GB. If some one have a guide that can help me I'll much appreciated
#50167
Make sure you’ve got Lilu and Whatevergreen in your Clover folder and they are upto date then follow this to install and enable the web drivers, https://amd-osx.com/faq/#gpu
by: PokeRio
#50192
Still having problems to make it works. I'll reinstall and try again
@eziodavinci , No issue there. That's normal for […]
AMDMacOSX Catalian
Yes that tutorial supports your setup. You need th[…]
Hey, Successful build on my machine. MSI x470 […]
Hy, I updated the LILU and Evergreen kext which f[…]
