by: Lamushi
#43054
Hi forum,
I am stuck at the pre-install bootup screen with this error. Trying to install Sierra but no luck so far. Any idea on this error?
#43058
System specs? Looks like you're using an incompatible CPU.
by: Lamushi
#43067
CPU: AMD Phenom II X4 B95 3.0 GHz
Motherboard: FOXCONN 2AB1
RAM: 9GB DDR3
GPU: GeForce 1050 Ti
Hard Drive: SSD 500GB
#43068
Highest version you can get on Phenom is El Capitan.
Lamushi liked this
by: Lamushi
#43072
I successfully installed El Capitan but when trying to boot it all I get is a black screen with a flashing dash line.
