by: Mellen
#43847
Hey @Shaneee,
thanks for the fix. This worked (almost) for most of the CC 2018 programs - except for InDesign. We still have to go with CC 2017 in this case. Also Adobe Bridge only works with the 2017 version.
Is there any chance that both will also work with newer versions in the future? We thoroughly tested all CC 2019 versions and were only successfull with Premiere CC 2019 and Media Encoder 2019 so far. :crazy: :crazy: :crazy:
I guess more and more people would jump on that Ryzentosh workstation train, if the Adobe Creative Cloud would work flawlessly.
Best,
Mellen
#43848
Mellen wrote:Hey Shaneee,
Best,
Mellen
Photoshop CC 2019 works too. You have to remove the FastCore and MMXCore plugins. Check for them in the other apps that aren't working for you.
by: Mellen
#43849
Wow, that was quick! Will give it a try :thumbup: InDesign is still a bugger and one of our most used products. Also, I guess we are stuck with After Effects CC 2018 at the moment.
#43850
Latest InDesign? I can install it and take a look.
Mellen liked this
by: Mellen
#43852
Shaneee wrote: Wed Nov 07, 2018 2:20 pm Latest InDesign? I can install it and take a look.
Yep, latest InDesign version (14.0). And still not able to make PS CC 2019 work, though CC 2018 works. Strange.
Thanks a lot, Shaneee
Already found and removed them. So Photoshop works too! Now only InDesign is remaining. I found and deleted FastCore and MMXCore plugins. But still it won't start ...
Thanks a lot @Shaneee,
Mellen
#43862
I've had no luck so far and had a few different crash logs. I'll keep trying though :thumbup:
Mellen liked this
by: anujpanchal
#47494
hello, illustrator cc 2019 does't open on my system ,and unable to install 2018 version ,please help me i am a designer , and i am getting late..
High Sierra
R5 1600 ,GTX 1060,msi B450M
by: enra enra
#53490
Hi Shanee,
Could you reupload the link. I managed to fix Adobe and Illustrator but not Indesign yet.
Thanks!
