by: Norton287
#31214
Gimme a couple of days to fix some things and upload the files.
by: zzmadd
#36795
Hi guys,
there's a new Security Update for Sierra 10.12.6 that came out yesterday or so: 2018-001 10.12.6
Is it safe to go ahead and update?
Thanks
#36799
It'll most likely replace the kernel. Have the USB installer to hand so you can run the post install to replace the kernel and rebuild the prelinkedkernel.
zzmadd liked this
by: blackcat
#36907
Has anyone confirmed the kernal fix after new update ?
Don't want to screw my computer up
@eziodavinci , No issue there. That's normal for […]
AMDMacOSX Catalian
Yes that tutorial supports your setup. You need th[…]
Hey, Successful build on my machine. MSI x470 […]
Hy, I updated the LILU and Evergreen kext which f[…]
