by: Norton287
#30849
If you've installed the 10.12.6 Security Update you know your machine won't boot. Here's what you need to do:
Boot off your USB installer macOS from SierraAMD, once install loads click on Utilities from the menu and select Terminal. Once Terminal opens enter the following commands:
cd /Volumes/SierraAMD/PostInstall
sh post.sh
Enter the name you named your macOS volume and press enter.
Let the script run and reboot without the USB and you should be ok. One thing you will have to do Post PostInstall is reinstall Nvidia Web Drivers for you Nvidia Card holders.
Shaneee, blackcat, anijatsu and 1 others liked this
by: jamkid
#30863
Hi, my trusty USB boots it up to a white blank screen.
Is there anything else I can do? My USB was left plugged into the hackintosh while the update was done.
Thanks in advance!
by: Norton287
#30865
Put your system specs in your signature it could be video related
by: jamkid
#30868
Added my specs as below. The white blank screen looked promising initially but it just hung there and slowly turned to a grey screen.
by: Norton287
#30871
When you boot go to Options - Configs and choose the RADVESA config
by: satelli
#30928
Anyone who replaced V5 kernel with Bronya's 10.12.6 kernel for AMD graphics card, be sure to backup your kernel (in /S/L/K) and System.kext (in /S/L/E) and swap the ones in the SierraAMD's PostInstall directory with Bronya's as well.
It's not necessary to run the full post.sh script again if you don't want to mess up your custom kext combination, just replace the kernel and System.kext introduced by the security update, and manually run
kextcache -u /Volumes/$your_volume_name
If you followed the SierraAMD tutorial, the $your_volume_name should be macOS, or the one you renamed to.
by: Norton287
#30931
You need to run the full script as it puts back bad intel kexts we don't need and the script removes them. Just use transmac to put bronya's kernel in postinstall folder and system.kext in files.
by: satelli
#30938
Norton287 wrote:You need to run the full script as it puts back bad intel kexts we don't need and the script removes them. Just use transmac to put bronya's kernel in postinstall folder and system.kext in files.
Norton is right. It is better to remove them though these kexts are not loaded.
by: xazp
#31211
Hi,
I just completed a fresh Ryzen VM-Ware install of Sierra (thanks very much!). I initially hit the "update" button and of course the VM stopped booting.
So I just re-installed it, and didn't hit "update" - is there an easy way for me to fix this problem prior to hitting "update"? Or should I just never update?
Thanks!
