by: Norton287
#30770
These are UVC cameras or Universal Video Class and supported out of the box, some may have software that comes with it but usually its just recording software or camera setup of mode, resolution, etc.
These are from Logitech:
HD Pro Webcam C910 V-U0017 860-000266
HD Webcam C270 V-U0018 860-000270
HD Webcam C310 V-U0015 860-000259
HD Webcam C510 V-U0016 860-000261
HD Webcam C615 V-U0027 860-000328
QuickCam Vision Pro for Mac V-UBM46 860-000143
#38539
Sierra 13.3.3
Logitech C310
working, but if I reopen Photo Booth the cam stays off and I get only a black image.
Workaround: Switch USB port, reboot
Idea how to fix this permanently?
#38543
Microsoft LifeCam VX-5000 works just fine. Has done with 10.6.0 to 10.13.3
by: handzo
#39087
Dear sir, could you help fix the problem to showing my usb Logitech HD Pro Cam C920? coz this case never seen trouble in my hackintosh intel system.
this peripheral just PnP before i decide changing to Ryzentosh. any sign about fixing something else maybe from genericusbxhci.kext driver that missing to work. i hope u can help solving this? there's something weird everthing looks normal in system information showing up either in cam or usb section.. but if i tried to launch the cam software,, everything just going blackscreen & no camera detected. these case make me confuse coz imperfectly running hackintosh in amd, in other stories are very satisfied with the performance of the zen processor running programs macOS better than my intel hackie
Screen Shot 2018-03-25 at 1.31.19 PM.png (142.06 KiB) Viewed 165 times
Screen Shot 2018-03-25 at 1.30.47 PM.png (115.23 KiB) Viewed 165 times
Screen Shot 2018-03-25 at 1.32.23 PM.png (1.45 MiB) Viewed 165 times
