by: vicgregor
#37391
zzmadd wrote: Tue Feb 06, 2018 10:48 pm It's not that straightforward as it depends on the USB compatibility of the motherboard. The relationship between Kernel and CPU generation etc etc...
The ASRock I had bad USB compatibility so needed modified kexts and eventually lead to reboot after waking the PC from sleep.
At least my Biostar make it seem to be all Biostar mobo's USB friendly to Mac. No need to fixes or anything, worked well straight after installation.
by: zzmadd
#38920
I got a
BCM 943602 based 802.11ac dual band 1300 Mbit/s WLAN + Bluetooth 4.1 PCIe m.2 NGFF
in short Dell1830 NGFF PCIe mini card and plugged it into my motherboard.
WiFi seems to work OOB even though it doesn't scan for available networks. But it's really fast with my WiFi once connected.
Issue is Bluetooth is not working.
It's seen under USB as BCM2045A0
Product ID: 0x6410
Vendor ID: 0x0a5c (Broadcom Corp.)
BUT it's not seen under Bluetooth and the system preference doesn't show up
I tried the Rehabman BrcmPatchRAM2 solution that can be found here https://bitbucket.org/RehabMan/os-x-brcmpatchram
BUT bluetooth still doesn't work.
Can anybody help?
Thanks
