#28666
HELLO GUYS !
This is the new 10.12.6 kernel for All AMD CPU's / APU's with SSE4.1 _by_bronya.
[ALSO SUPPORTS RYZEN AND THREADRIPPER CPU'S]
Note: FX users ,no need to install/upgrade to this kernel is you are already using 10.12.6 FX kernel by Shaneee.
Procedure:
- Install kernel file in System/Library/Kernels folder.
- Install System.kext using kext utility .
- Reboot.
(4.14 MiB) Downloaded 249 times
#28764
Norton287 wrote: Tue Oct 03, 2017 6:24 pm Use this guide to installing it
viewtopic.php?f=24&t=2711
Hi Norton287.....i did the tutorial in the video you linked but after reboot i still got the cant find mach_kernel.
In the tutorial i downloaded the fx amd kernel and put it in the system/library/kernel folder as shown and deleted the other file he mentioned...got kext utility to repair permissions but still got the error
any ideas? thanks
#28766
Did you get any errors on kext utility. See if you can boot off USB to desktop and run OnyX (see download link in my signature), run the first 3 tasks on the Maintenance tab.
#50981
The attached Zip file seems to be corrupted. Can you upload the fix one again?
Thanks!
