#28600
MickeyGP1378 wrote:
Wed Sep 06, 2017 5:22 pm
Ok so the install finished, I rebooted into USB again, ran the post install commands..... And for some reason when I try to boot from the HDD it just restarts after the +++++++++++++_
You could prolly help me as i keep getting ...macos cannot be installed.
I have an fx 8350 4ghz and ga-970a-ds3p mobo and a sapphire r9 290 4gb trix card and ive done what youve done with them setting.
i used transmac to do the usb stick and plugged into usb 2.0 port pressed f12 and booted under general.
It shows the list and i hit ok to boot sierraAMD. it shows the ***** line then the verabose and gets to the install screen.
I use the utility to wipe the partition im using which is MBR not GPT as it has other windows MBR partition along side it on same hard drive, anyway..
I had mavericks on this partitiion beforehand so surely sierra should work.
i then got it to start the install and got the 15mins remaining but i think it took about 2hrs or so ..and then showed....macos cannot be installed blah blah.
can you tell me what settings you used? did you get to install the operating system fully? how do i manually set flags as i notice that it already had those flags setup as i seen it in the verabose lines of txt.
I tried the usb swapping thing but my usb 3.0 stick didnt light up until i put it back into the usb 2.0 port and hit enter again
please obiwan your my only hope....so far hehe
#28603
Did you format the partition as GUID HFS+
#28621
no it was originally mbr with mavericks previously so just erased it. only way to format it with guid would be to do it to the whole drive i noticed ..cannot do with a single partition
hi i seen your link for v5.2 dmg and big thanks...it uses usb 3.0 port and the 15mins counts down to zero and was quick...didnt take 88mins this time and i didnt get cannot install error now...says reboot to finish install but when i do i not there is a... boot from.... and i have mine named sierraOSX but if you select it ....it just reboots
#28692
You can't boot from your hard drive you need to do the post install first. You have to boot macOS from SierraAMD again. Here's the tutorial for installation:
viewtopic.php?f=24&t=2707
#34728
It can take up to 4 hours to install depending on what type of port the USB is plugged into, just let the install run and it will finish.
#39451
Hey I have the same, stuck at 15 min problem but I wanted to ask if it’s normal for the HDD indicator led to not blink during the process, the drive is definitely spinning, but I see no activity indicator.
Install mojave from 0 (first time)
Hi, I would like to do my first Rayzen-Hackintosh […]
Cerisea Medica The preventative results exercis[…]
High Sierra 10.13.6 installer
1533mhz * 2 (dual channel) = 3066 mhz. that's abo[…]
