by: ObsidianX
#25076
Hey again, folks!
I've successfully installed SierraAMD 4.5 and have a functioning Clover boot loader but I'm now stuck trying to get the nVidia Web Drivers to load with my GTX 1060 3GB. I downloaded the nVidia Web Driver Updater and installed the latest version for 10.12.6 (378.05.05.25f01) and have tried the following combinations:
  • NvidiaWeb = True
  • NvidiaWeb = True, nvda_drv=1
  • NvidiaWeb = True, nvda_drv=1, NVEnabler.kext installed
With NVEnabler installed I do get a bit closer with System Info reporting an "Unknown nVidia card" with ~3GB of VRAM but still no acceleration. Is there any additional patching that I need for a 1060?
Never mind! I got it resolved.
I'm not sure which part solved the problem but I installed Lilu and NvidiaGraphicsFixup, enabled Nvidia Inject in Clover, downloaded the ROM for my graphics card and loaded up into Clover by placing it at /EFI/CLOVER/ROM/10de_1c02.rom, overriding the memory settings via Clover to the correct amount and installing the EmuVariableUefi.efi driver in Clover to ensure "nvda_drv=1" was being passed to the web driver.
Now I've got dual monitors running at 1920x1080 each with hardware acceleration!
Shaneee liked this
by: gremp
#25266
Hello,
From where did you download the ROM for your graphics card?
#25314
@gremp, Most likely from here,
https://www.techpowerup.com/vgabios/
by: mich8511
#44003
Hello
I can not activate full hardware acceleration. My card viedeo is a MSI GTX1060 6gb. It is really frustrating.
